Caldo71
Hey so I just finished this build and it sounds KILLER: really, really happy with how this sounds. Top switch positions sounds perhaps a bit more “compressed and modern” albuit quieter with a smooth top end, middle position much like an Agry Charles with (lots) more gain on tap.
That said, bottom switch position sounds identical to the middle position to my ears, and the blue LED does not light up in any if the three switch positions. Is it SUPPOSED to, or does it work in the curcuit in some other way I don’t understand?
And before you ask, yes: I did check to make absolutely sure the cathode was wired to the proper pad.
To add to my confusion, the pcb has the cathodes all facing the same way (see photo below) while the layout in the instructions (also below) shows them alternating. And when I play through the pedal, the red LEDs flicker satisfyingly in the middle position but not in the others. But all positions seem to SOUND good?!?!
