Stickman393
Well...after a few issues with my first attempt on this pedal (bad rotary switch, probably overheated the FV-1) I decided to rebuild. The first suffered from crackly static after initial attack...but it sounded great otherwise
This time I wanted to add an intelligent relay board in order to make it more like the V2...
Pin header between the two boards, foam tape on the back for the momentary switch. Makes for a solid connection that can absorb a shock.
Love this one...great little creative tool. Pics aren't great. But the artwork is inspired by a bonkers conspiracy theory regarding HAARP.
See...some of the same folks that don't believe that climate change is a think that the High Altitude Auroral Research Project is a front for weather weapons research. They also claim that these weather weapons are being used to...like...do stuff...basically anytime there's a weather-related catastrophy.
Cause, chaos is sometimes less appealing than the idea that the world is being controlled by evil doers. Or something.
The sign says "stop controling the wether". Shoulda used a finer bit. It's legible, but just barely. Live and learn.
