Thank you sir, you make a good point.you'll want series resistance on the ruetz mod or you're going to have a bad time when the pot is 0R
remember that those resistors don't just form a second order filter, they also set gain ... you'll end up with something closer to the forbidden setting on the expandora if you keep it as-is which ... maybe you want but probably not
I bet not. Rats nest pretty quickly.Nice clipping array! I'm still working on my breadboard version...I even thought about wiring an opamp selection between LM308 and OP07 (lots of jumpers....it's not pretty)
Sounds good. I don’t see it being a problem. I’m gonna order some boards and see how it sounds.This is awesome. I might give this a go when you get it verified. That hard clipping selection section looks cool to play around with.
Read about it on diysb. If it sounds bad, I can always put a GE or something else. Really, we can put any diode anywhere in the selector path.MOFSET+LED is one I have not tried.![]()
I had a helluva time coming up with more than just five. Position 8 is no diode. Then either just the feedback loop or nothing but the opamp can be chosen. The roadkill rat has diodes in the feedback loop. I laid out one of those with hard clipping diode options also. It sounds killer IMHO.It looks awesome, but I’d personally do a 1p12t rotary, and add some additional clipping modes, just because excess is fun. Probably some schottky clipping, as well as assymetrical LED clipping, some other weirder option, and also no-clipping.
Oh, no doubt about it— 8 is more than enough! I just like overdoing things hahaI had a helluva time coming up with more than just five. Position 8 is no diode. Then either just the feedback loop or nothing but the opamp can be chosen. The roadkill rat has diodes in the feedback loop. I laid out one of those with hard clipping diode options also. It sounds killer IMHO.
What about out of spec J201 & LED??????????????MOFSET+LED is one I have not tried.![]()
Me too, I was looking for one, but nobody makes one. The JHS thing is a multi, but not more than a couple of clipping options.Oh, no doubt about it— 8 is more than enough! I just like overdoing things haha
I’m not typically a rat fan, but I’m very much looking forward to seeing this in action!
LED and a Potato, I think sounds like an idea. Maybe a small Rusett.What about out of spec J201 & LED??????????????
