I was talking to my friend that I bounce all my ideas off of and he reminded me that the general consensus is that the power section of the Fryette D60 is the same as the main part of the Powerstation. This schematic doesn't have the reactive load (some good reading on those
here) and is missing the warm/brite switches, but it will get you most of the way there. It also doesn't have the power supply, but you can generally design that yourself based on the needs of the circuit, which also allows you to scale it if you want to use different tubes. I'm partial to EL84s, so if I were to design something like this for myself I could scale the power section to be more suitable for EL84, and I can choose a 15W design or a 30W. You do you.
I will of course echo the fact that this is not a trivial thing to build and will be expensive, but it will also be dangerous, please take all necessary safety precautions when dealing with high voltage. Tube amplifiers can kill you and it will hurt the whole time you're dying.
