Big Monk
So I had previously posted my amp I was calling the 5F184, which was basically my modified Valve Junior circuit from over the years. Since then, i've done some further experimenting and come up with what I am calling the JTM584.
It's essentially a 5W, SE EL84 amp but with some circuit tweaks to put it into cranked Plexi territory. As opposed to some of the early "Marshallized" VJrs, I've tried to strategically control the signal gain to accentuate and ape certain aspects of what I hear when I hear a cranked Plexi.
My hope is to try and finalized my "desktop" 1590DD design with my existing transformers and use a JJ 40/20/20/20uF cap can to save some space.
V1a cathode has an 820/680nF combo while V1b has an 820/2.2uF combo. Over the years I've tried almost every combo in these spots and these two pairs seem to be the most balanced to my ears between lower volume Tweed/Plexi cleans and grind when cranked.
The signal path of the 33k input resistor, 470k/330pF, 500kA Volume pot, 470k grid leak and 5.6k grid stopper was arrived at after years of trying stuff out. The 470k and 330pF treble peaker seem to provide the right frequency response. I've tried 100 pF, 220 pF and 470pF there over the years and 330 pF just sounds right. The signal limiting across the audio path and the 470 grid leak resistor seem to provide the right balance of signal slamming the grid and power tube distortion.
I've added a 1k screen grid resistor which was notably absent on all versions of the VJr.
The 40uF filter cap and 220uF EL84 cathode bypass cap strike a balance between softer/saggier Tweed response and the very firm sound of a Plexi power amp.
I've added a switchable Bright cap for low volume playing. I may also do a High/Low input as well for when I want it to be more pedal friendly.
Lastly, I need to determine how much (or rather how little) negative feedback to add. I'm using the AA784 Champ Amp style feedback insertion, keeping the V1b cathode bypass cap. The goal here will be to fine tune the cranked amp tone such that the notes don't get totally shredded when turned up. I'll likely tack in a pot and listen for the onset of slight damping and then sub that value.
![1719276094382.png 1719276094382.png](https://forum.pedalpcb.com/data/attachments/77/77461-05e3cd2c3de54d1f36c29941d20dc024.jpg)
