probably a really stupid question-
Atom ant
Hey all-
I was playing with a pedal today and a thought came to me- Is it possible to create a modification where you are playing a certain set of dial settings on a pedal, then use a footswitch to activate a different set of settings on the same pedal? For instance, lower gain cleaner sound on a pedal, then change to the same pedal with higher gain?
That concept can be expanded, from utilizing relays to venturing into digital switching and pre-set memory storage. An example of the latter, would be the JHS 'Muffelletta.'
