Paul.Ruby
If you want to make the 555 based board work, do this. Leave out the red-X components. Wire the reed switch as the green lines between pins 3 and 8 of the 555 IC socket. BUT, polarity is backwards, so, do not connect anything to "IN" on the module; Connect the input jack to the input of the wah AND to the OUT on the relay module; Connect the output of the wah to the "JACK IN" on the module. JACK OUT on the module is still the output. Of course... Programming is more fun.
I would use the intelligent module and program it.
Also leave out Q1 and R4, assuming there is no LED. If there is an LED, keep in mind polarity is backwards now.
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
![1737576498744.png 1737576498744.png](https://pedalpcb-forum.nyc3.digitaloceanspaces.com/data/attachments/89/89217-90b364dba6a29a34cd318d14cae7321d.jpg?hash=l_8iDyHMB9)
