Did you try asking ChatGPT to do it for you? (I joke, but there will come a day..)
I've started doing that on a few new projects. There's usually not room to mark them on the PCB though. I've put a few labels between lugs, but it's not consistent.@Robert - is there a chance to add switch position markings (position names, preset names, etc) in the schematics?
Great news!I've started doing that on a few new projects.
Do you just not like kicad? I ask because I’ve been messing around with kicad trying to transistion from the basic version of diptrace and for the life of me other than it being free I don’t see what is in anyway better.Finally had to upgrade to 1000 pins.
Totally with you @Big Monk , no need to learn a new workflow if there's no reason.
That said, if you are cranking out designs and want build docs.. KiCad is soooo much better for automation.
The original has about 1000 pins.Shit, the delay section alone exceeded 500 pins!
I wonder how the PCB size could be reduced if we switched to SMD. The only remaining issue is the tube. Keep it? Replace it with a JFET? Or maybe miniature tube?
YOU FUCKING WHAT NOWI plan on...losing the tube
PUT THAT THING BACK WHERE IT CAME FROM OR SO HELP ME
