Battery Damage to EHX NEO Clone
ReverendoRyan
Hey gang!
I'm taking a look at a Neo Clone for a friend, who unfortunately had a battery leak inside it. Symptoms are no chorus effect (clean passes through) and no lead.
First operation was to open it up, clean the corrosion. Nothing too bad on the board, the ribbon cable was a little damaged. So I took care of that first. Still nothing.
Decided to do a litte probing. Signal is coming into the circut. Once through it does go to the MN3207, and I am getting vibrato effect on the appropriate pins. The trimmer is doing it's job (small window of vibrato effect) and the C1M pot is affecting the rate.
Its almost as if its not "summing" Clean + Vibrato before going to the pedal output, just the clean shorting to output.
Concerning the LED, I know it's not fried because when I short it out it still lights up. There must be a short somewhere? I can take some pics of specifics if need be, but does anyone have experience with something similar?
Are you sure it gets toggled? Because if it was always on bypass, that would also explain the symptoms - basically what Robert said, but in a different manner (probably broken 3PDT instead of the wires being mixed up).
I guess since you probed it, that should have shown you if the chorus signal gets to the footswitch but not to output, so probably not it.
For figuring out the summing part of the circuit, a schematic would be useful, but I didn't find one with a quick search. Can you trace forwards from the BBD, or backwards from the output, to see if you can find where the vibrato signal disappears?
Symptoms are no chorus effect and no lead? What do you mean by lead?
Do you have a schematic of the signal path?
Where does the LED get its power from? Does it pulse with the LFO, or constant on?
If it's constant on, then you should pretty easily be able to trace it back to where it gets its power, or where its ground terminates. This should lead you do the problem
You are also going to want to trace your wet signal all the way thru to where it drops out. It's good that you're getting it after the 3207 chip, that's a good sign.
One thing that could affect the LED and the "summing" is the power section. If the LED is not receiving power, and the op amp stage at the end is not receiving power, then you will end up with the symptoms you have described. I would trace them both back to where they receive their power, and where their grounds are at, and see what you find.
Hey Gang, just a little status update
I figured a general place to start was a small clone circuit, and while i did manage to trace out a lot, my eyes just can't take reading SMD codes anymore. I gave it a shot, and learned a bit, but i'm hanging it up.
Thanks for all your input
