ReverendoRyan
Hey gang!
I'm taking a look at a Neo Clone for a friend, who unfortunately had a battery leak inside it. Symptoms are no chorus effect (clean passes through) and no lead.
First operation was to open it up, clean the corrosion. Nothing too bad on the board, the ribbon cable was a little damaged. So I took care of that first. Still nothing.
Decided to do a litte probing. Signal is coming into the circut. Once through it does go to the MN3207, and I am getting vibrato effect on the appropriate pins. The trimmer is doing it's job (small window of vibrato effect) and the C1M pot is affecting the rate.
Its almost as if its not "summing" Clean + Vibrato before going to the pedal output, just the clean shorting to output.
Concerning the LED, I know it's not fried because when I short it out it still lights up. There must be a short somewhere? I can take some pics of specifics if need be, but does anyone have experience with something similar?
