So this was a somewhat challenging build.
It’s a very tight fit. There is no room to play with the stomp switches. I had to fill and De drill enclosure to get them in the correct spot. I also had to grind down the lip of the enclosure to get it to close around the jacks.
I had replaced the opamp with opa2134 but had a real struggle with the bid. On a whem I replaced them with a couple of 4558d and it seemed to work.
The pedal sound pretty good sans a cracking and his when not playing. Interestingly it continues when it’s unplugged but goes away in bypass
