Wonder if anyone can help
My Acrobat is passing signal and the distortion works, but I have no action on the filter section
Turning the 'height' control to the right attenuates the output
The 'bandwidth' control is seemingly inactive
The 'freq' control might be doing a little something but it's difficult to say
I've used this particular 2p6t rotary set to 5 positions: https://www.switchelectronics.co.uk/products/2-pole-6-way-rotary-switch-splined-shaft-pcb-terminals
I did a continuity test on the rotary and it seems to be making sensible connections around the daughterboard as it turns
I've checked for continuity on the IC pins through to the back of the board
I've reflowed my solder joints and double checked the component values
Bit stuck now without a schematic
Thanks in advance
Thanks in advance
