That’s they beauty of 3D print. Pick whatever color! Black is what I did which should look good against the army green of the protein I’m buildingnice! or an illuminated clear one?
You’re welcome! My brother makes all my stuff so I’ll see if I can get him to print more.Thanks for the 3D file, I'll see if a friend can do it. I don't have any friends with 3D printers... I wonder if that's age related.
Did you sort out the 20k/25k conundrum? I think either would do, but I'm not familiar with either green or blue Protein and haven't seen a schematic for either, either.
@fig, I've always thought a clear spacer would help in a lot of my builds and wished it came with built-in LED ring. I guess that'd need to be injection molded or something, but I'd settle for just wiring up some LEDs with a regular clear spacer. I've got some plexiglass end-cut shards from a trophy shop to experiment machining on, but don't have the tools yet to do so.
So basically, I would just send this file to a 3D printer, right?
Yeah so my brother is the one with the printer and he just sent me this and said it’s all you need.So basically, I would just send this file to a 3D printer, right?
I was contemplating going with a bigger box at Tayda because I need a 1590BBS but would rather have color choice/UV print, your solution would be better after seeing how great your Protein turned out.
Thanks! Will definitely try it outYeah so my brother is the one with the printer and he just sent me this and said it’s all you need.
I was worried it might not fit perfectly because I used a tech drawing from Hammond but tayda seems to have used the same drawing to make their enclosures!
No problem! Post pics when you’re done! I’d love to see some different colorsThanks! Will definitely try it out
Yes for the love of god just buy a deeper enclosure! Don’t stuff things into a regular BBLoving this thread. Just out of completeness, Tayda has 1590BB2 which are 5mm deeper than 1590BB, so still not as deep as they get with the spacer but already better.
I meant 1590B, but apparently there is not a deeper version of that enclosure. Right? That would go a long way to making it easier to put a lot of boards into 1590B boxes.Is a 1590BB2 about the same depth as a 125B -- deep enough to have top mounted jacks and pots under part of those jacks?
There may be a 1590BS type box on some of the non pedal building sites. Try hawk electronicsI meant 1590B, but apparently there is not a deeper version of that enclosure. Right? That would go a long way to making it easier to put a lot of boards into 1590B boxes.
Digikey and Mouser seem to have some.![]()
Now good luck finding one
1590BS and 1590B2I meant 1590B, but apparently there is not a deeper version of that enclosure. Right? That would go a long way to making it easier to put a lot of boards into 1590B boxes.
