Many__Of__Horror
I can never get the indicator LEDs at the brightness I want. I test before hand but then might find in a dark room it is still too bright, or not bright enough. Always something.
I wanted to make a little PCB similar to the trimpot board available here but add in a minimum value CLR on the board for protection if the trimpot is dialed to zero resistance. Having a hard time getting my head around where I need to put that resistor.
Does this look correct?
Any recommendations would be really appreciated.
