I’m creating a new thread to troubleshoot the issues I have with this build:
I’ve just finished building the AION Fx Oceanid today and although its working reasonably well I do notice that it does have noise in the form of crackles. Single coils with the guitar volume on max don’t exhibit this issue but humbucker pickups with the guitar on max volume do have this issue. Reducing the volume to around 8 removes the crackles. Inside trim and playing around with the blend and comp settings don’t influence the crackles. The crackling issues is prominent with guitar and bass BTW. Same issue.
1. Could this be impedance or input related because reducing the volume changes the crackling issues.
2. Could this be related to the LM358N or P opamp as its known for distortion issues?
3. Original uses BC549c, maybe try that instead of the 2n5088? Although I’ve never had issues with the 2n5088.
Overall it’s an OK working compressor but I’ve played better ones that have more control over attack and release like the Origin effects Cali76. The inside trimmer is not doing much to the overall behavior and I find the blend to influence the compression in a peculiar way. The compression feels more like volume reduction with an attack that is too quick IMO and from no compression it kicks in too quickly when turning the comp knob.
Btw, this version of the PCB is different then the builds I’ve seen mentioned here before. The NSL-32 has been installed with the dot (-) top right. The other side of the PCB has the + noted bottom left. Not sure if it would work at all when wired reversely.
