REQUEST Aion L5 Preamp (Newer 9vDC Version) Drilling Template?
I used the drill template from Aion and added it to illustrator for my UV print.
I then used used a printed copy of the drill template and did it off school with my drill press. Seemed to work out perfectly!
There is a lot of holes to drill though!!
View attachment 88136View attachment 88137
That looks fantastic! Would you be willing to share the Illustrator file you used for the UV printing?
Of cause. See attached and let me know how you get on.
If you want the Illustrator one then drop me a PM with your email and I can send it onto you. I cant seem to attach it here.
Thanks! I tried to send you a DM, but it won't let me start the convo because it thinks I'm a bot... can you try DMing me and I'll reply with my email?
If you can't attach the file it is most likely not a supported file on this site, just add .PDF to the file ending.
Don't rename the file itself but place the .PDF after the .AI or whatever the file extension is. (File.AI.PDF)
We just have to remove the .PDF once we download it and all is good.
We would all like to see the file, especially me as I'm trying to learn how to make Tayda artwork for my boxes and the more examples I can find the better it is.
The only drawback for me is I will have to build the pedal for myself now.
Cheers
Mick
