Aion Termina (Timmy) to Jan Ray?
Noodles
I'm wondering if anyone has used the Termina PCB to create a Jan Ray clone. I'm starting with that PCB rather than the Tommy as a quick look (to me) suggests it's easier to change the values to match the Jan Ray schematic.
I've compared component to component and it seems pretty straightforward. I see the Jan Ray uses a B10K for the volume pot vs an A25K with a 18K resistor in parallel (isn't that basically a 10K pot, in essence?). I'm a little unclear on the log/antilog to linear practical effect. I know the bass switches from a "subtract" to an "add" control.
Here are the changes I'm planning to make. I would appreciate any comments regarding past experience or comments on my approach.
PartTermina ValueJR Value
C139n47pF
C247pF22pF
C3100pF47pF
C439n
C51uF
C610n47n
C72n2150pF
C81uF
C947uF
C10100uF
C11100n
R1510k1M
R23k3
R39k1
R4680R
R51k1k2
R610k3k3
R710k3k3
R818k
R98k27k5
R1010k9k1
R11100R
RPD2M21M
LEDR4k7
D11N5817
D21N9141N4148
D31N9141N4148
D41N9141N4148
D51N9141N4148
D61N9141N4148
IC1LM1458LM4558N
BASS_TRIM10k trimmer
GAINA1MB500K
BASSC50KB50K
TREBLEB50KB10K
VOLUMEA25KB10K
Having built both on Vero quite a few times I would merely say that the differences in use are fairly minimal and that the trimmer in the Jan Ray seems superfluous. I'd probably just as soon just use a Timmy. The Vemuram Timmy which I think really is worth building is the Ibanez/Vemuram TSV-808. I have my own version of it where I just use a simplified midrange and leave out the mid pot and clipping switches and it sounds very, very good. I doubt you could built it on a Timmy board though. You could definitely built it on PedalPCB's TSV-808 board though.
I've had a few real Timmys. I'm doing this version just to see if I actually notice any differences...plus it amuses me to do a clone of a (mostly) clone of a great pedal. Thanks for your thoughts. I'll check out the TSV-808.
If you decide to go down this route and try to build the Jan Ray on the Termina board, the value you have for C1 should be 47nF, not 47pF.
You have R9 and R10 swapped around. R9 should be 9.1KΩ and R10 should be 7.5KΩ.
I think that the rest of the values look okay. You may consider leaving the Bass control as an anti-log "C" taper, it's supposed to feel a little more natural for bass control in this circuit topology.
The clipping section does differ slightly between the two. The Jan Ray's clipping section is equivalent to having the clipping switch in the middle (off) position.
Good grief - thank you so much for the corrections. I had misread the discussion on freestompboxes re: the voltage divider.
Any thoughts on the volume control? I'm thinking of just leaving it at the Termina values since I think it gets to basically the same place. OTOH, if I used the Jan Ray values, I'm not 100% clear on whether I would leave the 18K/R8 position open or whether it requires a jumper.
