mybud
- Build Rating
- 5.00 star(s)
Ok, so here's another Simulcast, with an AC128 (with heatsink, at bottom right) subbed for the OC71. I breadboarded some alternatives beforehand and ended up liking the 128 best (hfe around 100, IIRC).
I had a senior moment or two doing the internal wiring, for some unknown reason swapping the in and out terminals when flipping the toggle switch but it works fine in any case.
Minimalist industrial aesthetic seemed to work well in the context and I like the sound more than I thought I might.
The Germanium and transformer combination bring a slightly different kind of grit to the table, although let's not rule out 'mojo confirmation bias syndrome' here. The gain variations successively add more obvious dirt so there is some room for more or less subtle or obvious grunge to taste.
Thanks for reading and wish you all joy with your builds meanwhile.
