Gotcha. Wasn’t sure. I haven’t done any builds yet that utilize these but I was kind of under the impression that it was near impossible to find the through hole versions. Just doing some studying. Thanks for the reply
They are expensive compared to most of the other components and if one were building pedals at a production level the smd versions would be a no brainer. For personal use I don’t mind forking over a few more bucks unless every pedal I was doing called for these.
A lot of folks selling PCBs are including SMD pads no for JFETs. If that’s offered on a board you’re interested in, I’d recommend going that way. The conversion boards are a good workaround if TO-92 pads are the only footprint on the board.
It's worth checking surplus shops if you happen to have them in your area - I grabbed a handful of through-hole J201s for a chop chop build a few days ago for about $.50/ea.
