nondiatonic
I'm getting a very loud pop when initially engaging the Awful Waffle. However, once it has been turned on once, it does not pop again unless power is removed (unplugged from power supply) and then restored (plugged in again) and then engaged for the first time after restoring power. In other words, I can turn it on and off without popping after that initial loud pop. I tried jumping the LED and that doesn't eliminate the issue. I was planning on rewiring the switch for true bypass to see if that fixed the issue, but before I went through the trouble I thought it best to post here to see if anyone has ever experienced this issue.
Thanks!
Thanks!
