Danbieranowski
Been a while since I did a build report, but this one turned out cool enough to share.
I didn’t mod the Amentum for bass, just left it as is and it sounds great! Had to squeeze everything into the 1590BB so the Amentum is mounted sideways. Themed for the Miami Dolphins for a friend. For the Amentum I subbed an MPSA18. For the Obsidius it’s all stock, including through hole J201s from GuitarPCB. Path hits the boost before the distortion to drive the distortion harder when desired.
Below is a video of what it sounds like through a guitar amp.
A cool mod for the Obsidius might be a footswitch that controls the Drive amount between two values, although I’m not sure how someone would do that. Like if you set it at low gain but hit the footswitch to top the gain out or return back to the knob value.
Print work is by Tayda.
Party on.
-Dan
Party on.
-Dan
