Black Arts Toneworks Pharaoh schematic vs LSTR
chongmagic
It looks like the schematics for these two are similar except for the NPN transistors and some of the components are different values. My question, is that if I took the board for a Pharaoh and substituted the trannys and other values, theoretically would that work?
The Pharaoh has a switched clipping section that I suspect would work the same way in the LTSR circuit variation.
They’re both BMP variants. It’d probably be easier to use a BMP board than adapting the Pharaoh board since you’re not using the series input resistor selector nor the clipping diode selections.
Edit: the tone stack has the AMZ presence control. Using a board with the extra pot for that control would be easiest.
