Fingolfen Well-known member Nov 28, 2022 #1 Looking at the Bloodshot Overdrive, we've got two 10K trimmers presumably for biasing the transistors, should this be done by ear, or are there recommended voltages (and what's the quick and dirty way to measure them)?
Mcknib Well-known member Nov 29, 2022 #3 Usually 4.5v for the 5089 collector and 5v ish for the 5457 drain FETs aren't always consistent so start with the drain at 5v and see how you like it Measure the collector and drain pins referenced to ground start with the trimmer halfway and adjust as required Last edited: Nov 29, 2022
Fingolfen Well-known member Nov 29, 2022 #4 Mcknib said: Usually 4.5v for the 5089 collector and 5v ish for the 5457 drain FETs aren't always consistent on so start with the drain at 5v and see how you like it Measure the collector and drain pins referenced to ground start with the trimmer halfway and adjust as required Click to expand... Thanks!
