Hey guys,
New here, first pedal build and trouble shoot. I am building a blue breaker and by pass works great but when I switch it on i get no output. i made an audio sniffer and i get sound into pin 3 (and none oft he other pins) of the tl072 but no sound coming out. i swapped op amps that i had extra and all 3 same issue. Im unsure about how the ic actually work would the next step be to check negative voltage on pin 2 and or make sure there is good continuity to pcb ground on pin 4? any help would be appreciated. looking forward to being part of the community!
