droneshotfpv
Did you ever try a different BIAS voltage? What did you think if you did? I just built mine, and at first I screwed up with the BIAS. Instead of reference ground in the circuit for setting the drain, I used the 3rd leg as a grounding point. The results were terrible. However, when using the sleeve ground of the input / output jacks, and then set the Drain voltage to 11.11v, it sounded WAY better.. I am going to fool around with it this weekend to test a few other voltages, as well as using a 7660s in place of the 1044MAX charge pump, and then see what results I get.I biased mine a little under 9V, I'll have to try the 11.11
@daeg , in your illustration above, which was extremely handy for me BTW, so thank you.. you said "
JHS probably biases right at Vd=0.5*Vss (9v) like in the Superbolt, but this just sounds sweeter, albeit a little lower gain." So, in this reference, were you stating that the Vd in this example is = to 4.5v, then add the formula above for 0.7*|Vp| (in my case, that Vp = 0.539 as my J201's read 0.77 for all 3 (from Stewmac)? So essentially, in my case, that would be a BIAS setting of 5.039v? I have not tried it, but if that was what was suggested as per what JHS sets, I might try it and see what it's like as well.
For me, @11.11v , the PUSH control is stupid loud (in a good way) but forces crazy clipping immediately. I have also noticed the SWEEP knob and MID control knob have interesting effects on the circuit. a lot of MIDS turns the volume up even louder (while increasing MIDS) and the sweep can make it REALLY muddy all the way to the left. Tone control is also one that seems to NEED to be set PER whatever you dial in, no setting it and forgetting it where it sounds good for one dialed in sound, I seem to need to change it anytime I make a chage to gain, MIDS, sweep and PUSH, or else it gets kinda muddy / sounding like I rolled off my TONE control on my guitar.
Any info anyone has or suggestions to try to get the BEST sound, I am all ears. I will be tweaking this weekend for sure!
