I built the Bootleg (Moonshine) with a 3-way switch and sockets for two of the diodes (D4 and the LED). The pedal sounds great with the switch on D1/D2 or in the center (no diodes). However, it sounded a little off with D4/LED diodes installed per the build instructions.
I starting poking around with my meter. With D4 and LED removed and switch in the center (off), I get continuity across the red and blue areas, which should correspond to the areas I've marked on the schematic (see pics). However, that would mean both anodes of the D4/LED diodes are on the same side of the circuit, which does not match the schematic. To make things more confusing, I went back to the LED polarity thread, and it seems the screen printing on the board is opposite (A is on the square pad instead of the circle pad).
I did flip the LED around and it sounds better to my ear. I'm speculating the A and K labels on the board and build instructions are swapped for the LED, or perhaps I've misinterpreted something. Hopefully one of you can clarify for me and everyone else. Thanks!
