Laundryroom David
Keyboard Cowboy 🤠
As @Guardians of the analog has reminded us, the DS-1 is classic and essential. How ‘bout a PPCB version? I’d build it!
Upvote
11
Fair enough!Why build one for €50 with a TL072 when you can buy one for €40?
This is in progress.If you're going to do it, go waza.
I had a broken sounding distortion with both TL072 and JRC4580. The suggested change fixed the issue for me for both opamps.
I wonder if snipping D3 would helpInteresting.
When I was prototyping the Patron Distortion (which is a modified DS-1) I tried a TL072 and 4558, both sounded terrible and off bias.
I retraced the circuit thinking I had made a mistake but found nothing.... Using the correct TLC2262 sorted everything out.
I just don't see WHY it would bias weirdly with both....
I agree. It certainly wasn't my first suspicion.
I built one, it sounded awful. I swapped the transistors and opamp, didn't help.
By this time I didn't have the original anymore to compare against so I had to get another one, also just to confirm that it wasn't supposed to sound like that. Retraced it, everything was correct.
Built a second one. Same thing.
The only difference was that I wasn't using a TLC2262... ordered one, popped it in and it cleared right up. Swapped back to TL072 / 4558 (both genuine), the problem was back.
I'm not sure how this translates to the stock Boss circuit, but in the case of the MXR the TLC2262 was critical. (unless, of course, you want it to sound like a broken Superfuzz)
