Okay, so here's what I ended up doing. I used my C10K and put a 1.5k R between lugs 1 and 2. I wanted a 1.2 but didn't have it. Then I connected my 47 Ohm resistor in series and plugged everything back into R6 on the PCB which is socketed, thankfully. There is a noticeable difference now and the pot definitely makes a difference. Not sure if I love it though. I really need more time to play with it. I also took the time to play with a couple different IC's and swapped the diodes for red LED's in different combinations. This is a fun pedal. At the very least, I'm going to install a toggle switch for different clipping options. I'm kind of running out of places to drill holes though lol.
Here's how it looks in all it's test glory (did I do this right)? And then a few of the mostly finished pedal. Yeah, wiring is a bit of a mess.
