eh là bas ma
Hello,
I am building a Black Eye, and unfortunately i made a mistake with the tubes pcb :
I soldered the pins to mount both pcb on the main board, as described in the EZ Tube build doc (pins coming from the side with a circle).
Then i soldered both tube pcbs on the main board, but with the wrong orientation !
I didn't notice the silkscreen on the main board, my pin connectors are pointing toward the opposite direction from the silkscreen.
The tube pcb circles are facing the bottom of the enclosure.
Now I have the sushi box logo pointing toward the jacks, and if i proceed with the tube sockets, they will be soldered on the sushi box logo.
Both tube pcb are slightly closer from the top of the box, instead of being perfectly aligned with the bottom of the main board. But there are still enough room to fit the tubes.
I wonder if this is going to prevent the circuit from working ? Wrong pinouts ?
I am not sure if i'll be able to unsolder the pins, there are 10 of them on each pcb... Is it Game Over for this build ?
If there is some issue with both my tube pcb orientation, is there a way to work around it ? Some way to correct the wrong pinouts, or cut off the connectors ?
drive.google.com
Thank you for your help !
BE Build Doc.pdf
drive.google.com
