laundryman
I was so close to finishing my first PCB attempt with the Mahayana Drive then I messed up on the 9V power jack on the PCB. I did a bad solder on it, desoldered, then continued this cycle several times and now the pad is completely gone and solder won't even come close to forming and sticking at the base on the pad. It just bubbles around it and forms cold solder. Is there any chance at making this work or should I just give up on it?
Thanks.
Thanks.
