Technically you could, the 3.3V regulator will drop the 18V down to the required 3.3V for all digital circuitry.
However, you'll be wasting more current (and generating more heat at the regulator).
I'm not sure that you'd benefit from it since the FV-1 is the bottleneck for headroom and that won't change with higher supply voltage.
