Hi
I've just built up the "CDXL reissue" and it seems to be very quiet. So I started a research and found similar threads:
but a solution hasn't been posted.
@BipolarBear , @apc42069 : did you get your pedals running?
@everyone else: other ideas?
Thanks
HI K O
CDXL Reissue, Extremely Quiet
Whats up all, Just built the CDXL Reissue envelope filter, but when it's all together I'm getting almost no signal at all (without any effects either.) LED and true bypass are working as intended. Could this potentially be an issue with the LM358? I messed up the tayda order and got the SO-8...
forum.pedalpcb.com
CDXL Reissue Envelope Filter
greetings pedalpcb braintrust- I just finished this build, and man I got some problemos... When I first tested the circuit, it worked perfectly with the toggle UP. it was completely dead with the toggle DOWN. Assuming an overflowed lug / grounding issue, I desoldered the toggle & replaced...
forum.pedalpcb.com
Thanks
HI K O
