Bricksnbeatles
What mods are most worthwhile in your opinions? I've been looking for a cool pt2399 based effect to build for my 23rd birthday next month, and last night I settled on the Chalumeau.
First off is the matter of gain- If I understand correctly, the gain of the 386 in the circuit is 200, due to pins 1 and 8 being tied directly together. that should mean that c2 and r2 are completely redundant in this circuit, as they'll only set the gain if pins 1 and 8 aren't shorted together. c2 and r2 should give the gain of the non-fuzz version of the Clari(not) if you cut the trace between pins 1 and 8. of course, you could always cut the trace, populate r2 and c2, and connect a spst between pins 1 and 8 if you want both versions of the circuit, but why not take this in a different direction and just do a gain pot? If we cut the trace between pins 1 and 2, and then also leave c2 and r2 unpopulated, then we should be able to wire up a 1KΩ pot between pins 1 and 8 for a continuously variable gain between (I think, I'm doing mental math rn) 40 and 200. any thoughts or corrections here? I haven't double checked my calculations yet...
Next is the mater of delay feedback. more on that soon...
