Hi All
I've been working on the Chauffeur Overdrive as my first pedal build.
First of all, the inspection of all the parts and the PCB.
Fortunately, I found that one of the PCB patterns is disconnected in the middle of the line between R13 - IC4 6pin (faulty PCB). Anyway, so I patched it up with a wire.
When I turn the pedal off (LED off), I can get sound through the amp (bypass mode).
However, when I turn the pedal ON (LED is ON), I do not get any sound through the amp. Just quiet (no hum) Even if controlled the 4 knobs, nothing changes.
Does anyone have experience with this kind of problem? Or know how to fix it?
Before I give up, I just want to hear someone's technical opinion.
I will be grateful for any help you can provide.
Cheers. Marcus.
Cheers. Marcus.
