Check my SMD work - Pythagoras
zipfool
I'm working on Pythagoras. It's my first build with SMD, and I'm seeing some continuity between some of the pins.
I haven't soldered any of the other components on the board yet. Just the Spin IC. I'm getting continuity between the following adjacent pins:
1---2
6---8
11---12
18---19
24---25
It's not to say there's no continuity between any of the other pins...I'm just checking adjacent/near adjacent ones for solder bridges.
Based on the wiring diagram, it looks like everything is nominal. But I want to double check before I move on. Anyone able to confirm?
Hi guys, wondering if anyone has voltage measurements for the IC chips in the Pythagoras Build. I just finished putting everything together, and get no changes to the output from any of the three options that engaged when changing the position of the toggles switch. I get clean output, so I have a bit of troubleshooting to do. I figure I can start by checking voltages, but have nothing to go by. Any help would be great !
thanks !
