Chuck D Bones Modded Dark Esbat / Ember Boost
MattG
A few years ago, I build the PedalPCB Ember Boost, which is based on the TC Electronic Spark Booster. This is marketed as boost, which it certainly is, but the "fat" and "mid" modes also make it useful as a light overdrive; the Baxandall tone stack gives it a fairly flexible EQ. The core topology is similar to a Bluesbreaker-style pedal.
I really liked the Ember/Spark Boost in "mid" mode, but personally didn't find too much use for the "fat" or "clean" modes. I had actually started some napkin sketches of how I could mod the mode switch to be more in line with how I wanted to use the pedal.
Before I got too far with those plans, @Chuck D. Bones managed to read my mind and work his magic on the Dark Esbat. The PedalPCB Dark Esbat is based on the Black Country Customs TI-Boost ("TI" for its endorser, Tony Iommi). The Ember/Spark Boost and Dark Esbat/TI-Boost are the same circuit, with only a couple minor component value changes.
Not only did Chuck rework the mode switch, but he took it a step further than I could have, and simplified the circuit. The original circuit had some fluff; in the end, the modded version omits a whole opamp, plus a number of resistors and capacitors.
I'd been meaning to whip up a PCB of Chuck's modded Dark Esbat/Ember Boost for a while, and finally got around to it a few weeks ago. The PCBs arrived last week, and I had some time to assemble the pedal this weekend. I paired it with my pre-made buffered electrical bypass module. The enclosure is the December 2024 Limited Run from Love My Switches. The clipping arrangement is two pairs of three series diodes. For each triplet, I used two BA282 and a 1N4001.
It worked on first power up, no drama! I just sold my Ember Boost, so couldn't make a direct comparison. The role I intend for this pedal is for a touch-sensitive dirty boost/edge-of-breakup pedal with a flexible EQ, to work both as a very light drive and/or to push a medium gain drive (such as the Hard Rock Pinnacle). The nearest "competitor", and the pedal to which I was directly comparing, is the Cast Iron (Lollar Overdrive). I was able to quickly dial the modded Dark Esbat in where I wanted it. It's too early to say which I prefer, as I need more time with it to get a better sense of the "feel". But straight away, I can tell it absolutely meets my expectations.
The mids switch is really well tuned: almost too well-tuned, as I couldn't figure out which setting I like the best! In theory, I like the idea of the flexibility of an actual pot for mids (or any EQ, really); but in practice, I like the simplicity of a well-tuned switch. I think this is one area where Barber pedals have really nailed the "user interface" for pedals, particularly for gigging. Pedals like the Gain Changer or Direct Drive have (at least to my ears) a really great core sound, almost perfect with all knobs at the noon position. The knobs are more for fine-tuning, rather than forcing a square peg into a round hole. And the versatility (or "changing the shape of the peg") comes from the switches, rather than having to re-tune all the pots when you want a different sound. So this pedal I feel is a nod in that direction, which I appreciate: spare me the self-induced neurosis of trying to perfectly dial in my mids, just give me a switch with a few good settings! Chuck D Bones: "hold my beer".
Any way, I'm super-happy with this build. Eagle-eyed readers will note the PCB revision is v1.1. I drew up v1.0, wasn't happy with the layout, and completely re-did it. I still didn't think it was a great layout. So I never fabbed v1.0, and instead drew up v1.1. I shamelessly stole the top-of-board shape from the Dark Esbat. After more hours than I care to admit, I ended up with what I think is a decent layout. I was able to route almost all of the traces on the front side of the board; the back is satisfyingly tidy.
I have a few extra boards that I'm happy to send out to anyone who asks, just PM me. I'm also happy to post the Gerbers if there's any interest.
Looks really nice Matt, especially in that enclosure. I feel bad for asking but if you wouldn't mind me stealing your work, I'd love a copy of the gerber for my own personal use.
Oh, and nice solder pads for the diodes on v2.1 I see. 😂
I assume you're referring to this discussion. Note that this Dark Esbat CDB mod shown here uses a different switching system: it uses a CD4053 for the actual circuit switching - it's an electrical switch, as opposed to a relay/mechanical switch we discussed in the other thread.
Sure, attached! Note that it's a zip file, but I added the ".txt" extension to comply with the forum software. Just strip away the ".txt" after you download it.
BOM also attached. Let me know if you have any questions!
Just wanted to post a follow-up. I've been using this pedal since I built it, and it's pretty much exactly what I wanted: a Spark Booster better tuned to my needs. Chuck managed to read my mind when he tuned and tweaked this circuit!
Comparing the modified Dark Esbat to my Cast Iron, the Cast Iron is definitely more transparent. I know that description makes people cringe, but for me it means that the pedal can be set such that you can't tell if it's on or not, and those settings are fairly neutral in terms of pot sweep (noonish). That's why I've always considered the Timmy (and therefore the Cast Iron) to be very transparent, because their "default" state isn't too far from bypass mode.
The modified Dark Esbat is, to my ears, decidedly less transparent than the Cast Iron. But it's not a radical change in voicing by any means. And I'm not demanding transparency here. I decided I'm not a huge fan of the passive treble roll off in the Timmy; what I don't like is that if you roll off too much treble, it also lowers the overall volume. The frequency response graph illustrates this really well. So the result is, if you regularly use different guitars with fairly different treble output, you can't simply dial the treble knob up or down - it also requires a volume adjustment... which in turn might require still more EQ fiddling.
So at least in this dirty boost/edge-of-breakup/next-drive-pusher role, I definitely prefer the active Baxandall EQ controls of Chuck's modified Dark Esbat.
And as I alluded to above, the mids switch is indeed really well-tuned (at least for me). I've mostly been playing my P90-equipped Yamaha Revstar lately. And I find the middle position perfect for this. When I switch to my G&L ASAT, I find the low-mids position better suited (which makes intuitive sense to me, as the ASAT, being a t-style, does have more treble presence/less bass comparatively). I haven't found too much use for the high-treble mids setting, but I suspect it would be perfect for a humbucker equipped axe.
Lastly, since this Dark Esbat mod walks the line between boost and light overdrive, the gain knob has a lot of useful sweep for dialing in that "just right" amount of breakup, where you can easily go between clean and light dirt based on pick attack. Sometimes this is hard to dial in with a "pure" dirt pedal, because that sweet spot on the gain knob is so small.
I've been searching for the ideal light drive, edge-of-breakup, boost, EQ-shaping, works-with-all-guitars tool to pair with Chuck's modified Animals Diamond Peak as a 2-in-1 for a while now, and I think I may have finally found it. I have one more light drive I just completed that needs to be put to the test, but this Dark Esbat mod is going to be tough to beat.
Edit: the other thing I wanted to add, as I've built and tested different pedals, I find there are some that, at least for me, sound better at home versus in a band mix. Finding a drive pedal that sounds good in both roles is pretty rare. And this modified Dark Esbat seems to have that magic: it sounds great at home, and just as great with the band.
