BuddytheReow
Breadboard Baker
BuddytheReow submitted a new resource:
Circuit Block - Booster - Super Hard On (SHO) - Second Stage+ Clean Boost
Read more about this resource...
The Super Hard On (SHO) Booster. A neat little circuit snippet with TONS of boost on tap. The main differentiator in this circuit is that it uses a MOSFET instead of the usual BJTs or JFETs to amplify the signal. MOSFETs are finicky creatures in that they are very susceptible to static electricity damage. If you were to google a SHO schematic you will see zener diodes being used to help protect the MOSFET here. This is assuming that the first circuit block being used is a SHO. It should be...
