Pedal_man86
Built the Clandestine Preamp, works okay for the most part but I'm having a few issues.
1) The volume has a slight drop once the pot is turned all the way up
2) Not much, if any, difference between the mid and the dark settings.
3) The bias voltage seems a little strange, the lowest voltage I have is 12 Volt with the trim pot all the way down. Should I swap the transistor?
I saw another thread where other people had these issues, so is it a design flaw with the circuit, does the pedal it's based off of behave this way, and can these issues be fixed?
