So I'm working on the Chela OD,how would I use mosfets as clippers? I want to wire a switch between the regular clipping (red LED) to mosfets for a different, softer attack/clipping.
The links jimilee and I posted both do the same thing using slightly different wiring. They give you two options depending on what you connect to the outside poles.
You could get a third option if you use an on/off/on switch. When OFF, you would have no clipping diodes.
