Collateral FX Cabeça de Bode (Big Muff Ram's Head)
Guilherme Collateral
I've been so busy lately and with so little time to post around here, but I finally took the time to build something nice to post! It's a Cabeça de Bode (witch translates to Ram's Head in Brazilian Portuguese) and of course is a Big Muff within the Ram's Head specs and a toggle to switch in some roaring mids. The transistors are Philips BC550C and it sounds really good! Hope you enjoy it.
Beautiful build !
Do you think the Mid switch is interesting ?
Would it be worth it to add this toggle on a similar build ?
Thank you! It really makes a difference. Sounds a bit different from you everyday Muff but you can sit nicely in the mix without using another pedal to shape the mids. I recommend it! In this one I use a 6n8 for the tone control and the switch puts another 6n8 in parallel with it
