PAGOON
I just put together the comprehensive drive and and when I went to use it there’s no sound but it has sound when the pedal is off. Here’s the question I noticed after I had plugged in this pedal that I had the 4558 ic upside down o was wondering if I may have burned out some component. Also I didn’t have a 1k05 resistor so I just used a 1k I doubt that makes a difference hahaha… and also I double checked and went through and resoldered all the sketchy possible cold weld solders… tomorrow I will double check the resistors but I’m pret sure they are all correct here’s som pictures …
Any insights greatly appreciated
