Here's my quick & dirty fix. I lifted the ends of R2, R7 & C7 that are closest to the center of the board. I removed C6. …
Great news!!! This mod works! Thanks so much, Chuck.
I just cut the trace and added the bypass cap and now I can max the fuzz knob in big mode with no oscillation. All is well.
I'm shipping this off to my friend Aaron who is struggling with his band trying to make an OD sound like a fuzz.
I'm assuming I don't need to lift the components and cutting the trace is adequate (?) since you already lifted the parts to prove it works.
All trimpots have been reset to give 4.5v on the drain of each JFET.
If I try really really really hard, I can still achieve a small amount of squeal, but that is with all 3 knobs maxed out and only with hot humbuckers. If I split the coil on either humbucker, the squeal goes away. (It's also only at the very top end of the volume pot.) Only mentioning this for due diligence for future travelers. There is no musical scenario in which you'd max
any of the 3 knobs, let alone all 3. (Well, maybe the fuzz you'd want to max for mad sustain, but that's been fixed.) Unity volume is around 9 a.m. Max treble is a tad harsh. Max volume is socially irresponsible.
Played for another hour this evening. My daughter appeared at the door and asked me to turn it down.
Another successful build.
Thanks Chuck. Thanks all for being here in this land of sonic possibility.
