Hey everyone,
I just finished putting together a build of the Covert but I've run into a problem. The Pre-Amp/Gain control doesn't seem to do anything at all. I can run the pot through a full sweep while playing and here no affect on the sound whatsoever. I've already taken the build apart and replaced the A1M pot, just in case it was faulty. That had no impact at all. Everything else about the pedal seems to function as you'd expect, with the exception of the Pre-Amp control. Any suggestions would be appreciated.
Edit: I wanted to add that I ~think~ the pedal is basically stuck playing maximum gain, regardless of the Pre-amp setting, but I'm not sure since I really haven't been able to adjust the gain one way or the other.
