finegritmusic
Ok I know it's pretty rough work but I'm hoping I can salvage this. This was the first pedal I tried to build and didn't work. I've built many others since then that have worked and thankfully I've gotten much better at building. However I know I messed things up on this and wonder if someone with more technical knowledge can help bring this thing to life.
Power seems fine and LED lights when on
Pedal passes signal when off, however Gain knob seems to slightly effect it at different positions?
When turned on, Volume seems to work fine. Gain gives no output in middle positions, very distorted in low and high regions. Tone knob has to be tapered all the way down, when turned up it self oscillates and squeels.
My thought is that I screwed up the board on the input and output sections by scratching it up and this is the cause. Does this seem like a possible culprit for this? I have enclosed pictures to show what I mean.
If this is the case, is there somewhere else I could solder these connections. Or could this be something else entirely?
A million thanks to anyone that can help, this thing has sat in the bin for too long!
