D3lay not affected
uptown_sniffer
When playing guitar through the pedal the mix and level knobs affect the signal, but the others do not. The non-audible pots measurements change when they are rotated. There is no audible oscillation. The FV-1 seems to have normal voltages. Is there a signal path I can probe to solve this wacky mystery? Any perspective is appreciated. I am aware that I need to clean up the soldering and leads. d3lay.jpg
You can also access the programs built into the FV-1 by grounding pin13. you can do this by slidering a wire onto whichever side of R5 connects to pin13 and grounding that wire.
This would get you the patches 0, 1, and 2 listed here (depending on toggle switch position).
