debrad
Hi Everyone!
Having searched the forum and read several threads on troubleshooting the Parentheses Fuzz, I still can't seem to solve the problem I'm having so I'm hoping you might be able to help me out...
A friend of mine recently asked me to debug a pair of Parentheses builds he was working on. The first thing I noticed was that a) neither board had any function in the distortion, octave, or boost circuits..and b) neither board had any measurable voltages beyond D100. Fortunately, one board roared to life after swapping the polarity of the DC jack so I was hoping the same would be true for the second. Swapping the DC jack polarity DID fix the octave and boost circuits on this one but the distortion is still not working right.
Engaging the distortion switch completely silences the output and when I run audio into the pedal I can only trace it to the board's input pad. By the time the signal reaches the first component (R1), it's just a frequency tone. I can alter it with the distortion controls, boost it with the boost switch, and switch octaves with the octave switch but I can never hear the actual audio that I'm sending into the circuit.
Does this sound like a problem between the input pad and the first component or is it more likely that an issue downstream is impacting the signal at R1 (I get the same tone at R2, R3, R4, and Q1)?
I look forward to your suggestions!
Thanks,
- brad -
Thanks,
- brad -
