Delegate Compressor sustain knob causing distortion
Fireside79
First time pedal builder, so bare with me if I’m missing something here, but after completing the build, if I turn the sustain knob past 9-9:30 there is a fair amount of distortion that’s introduced.
I also need to have the level knob down REALLY low or I’m getting a massive boost to my signal…
Attached are a few photos
Without examining the pics, I'll suggest...
Check all your resistors to make sure you've got the correct values in each location.
Note, there are resistors with colour-bands that are tricky and should be measured with a DMM (outside of the circuit) ... for example:
The volume bump could be from having a 120Ω resistor in place of a 10k. R15, for example.
brown black black red brown = 10k
brown red black black brown = 120Ω
Which might also explain the distortion, by way of overloading the circuit.
