Hi, it looks like this PCB layout was done in May, but it's not materialsed is that due to the current situation or was there a problem with the design?
And it would be great to hear feedback from anyone who's compared the two. I'm deciding whether to jump in or wait!
I would also be interested in an updated PCB! Debating on whether to buy the current one or to wait.
I left out a "1" meaning OPA 2111, but your response covers it, thanks! Looking forward to the build.OPA211 is a single and OPA2134 is a dual, so no, they are not interchangable. Any FET input dual opamp will work, some better than others. If you don't have an OPA2134, then try a TL072. OPA2211 is a dual, it's not FET input but has low bias current so it will probably work.
Could share the link to the schematic
Ah okay. I didn’t understand what you meant there.
Not sure you need a BLEND knob. I can understand using it with distortion or filter pedals when playing bass. The RATIO knob essentially does the same thing as a BLEND knob in the Warden / Delegate / Col. Klink. It's like a clean bleed.Maybe I made a bad solderpoint or used a bad cable when I connecting IC1.1 with C14, will check it tomorrow.
One thing is for sure: Without your mod the pedal sounds awful in a lot of settings. Can't believe EQD sells theirs without!
Will also build in a blend knob with integrating a jfet buffer between C1 an IC1.2.
Being able to mix in the original signal makes really sense for bassists in most pedals.
Maybe it is a welcome upgrade for some of you too. Colognel Klink might be happy about a german plus
Could share the link to the schematic if you like, it also values your mod.
Hope we can come up with a random source or something in the future, creating a real Funny Bot Pedal in dedication to the South Park Episode![]()
The Ratio knob is not very effective anymore after I did the major mod. Also the Tone pot brings not the highs back like it did before.Not sure you need a BLEND knob. I can understand using it with distortion or filter pedals when playing bass. The RATIO knob essentially does the same thing as a BLEND knob in the Warden / Delegate / Col. Klink. It's like a clean bleed.
I don't have a short answer. I'll give you this to ponder until I have the time to formulate a better response...CDB, another Bass-sick question for you. How does the output cap affect output impedance?
I'm seriously under-educated in regards to calculating input/output impedances, I've recently started to try and correct this deficiency in my knowledge. I've read some EE-forums, and more closely related been reading pedal-forums info... and relative to this thread trying to relate all that back to the Delegate Boneyard specifically.
This was the most helpful info I've found thus far:
RG Keen does a pretty good job explaining things so a non-EE pedal-punter like me can understand things, and I almost do. However, he glossed over the cap by making it 10u, out of the range of relevancy as it relates to output impedance.
In a nutshell, I'm thinking of exchanging the 1u caps in C5 C9 & C11 for 2u2. I realise there's probably very little difference in expanding the low end by going above 1u, but I've got the 2u2 caps and thought I'd try it anyways (kind of like how AMZ's MOSFET boost is fine with bass, but was cap-bumped nonetheless in the Cat'bread Sagrado Poblano Picoso). My thinkering is that I don't want to swamp the detection circuit by making the input cap 2u2, but hope to ensure some good low-end escapes the circuit.
Anyway, I've tried to do my homework and not be just spoonfed an answer, but I'm still hungry to find what if any affect changing the 1u output cap (C11) to 2u2 will have on impedance.
Many Thankages![]()
