Feral Feline
Okay, thanks. I remembered that the output impedence is affected by the input of the next pedal in the chain.
Only Chuck can tell why he changed the values of the input buffer. I don't want to risk soldering too much on the board, so that is why I want to knowDon't know about the mod, but you'd have to ask EQD about why an EQD pedal was built so strangely.
Nice job!
Be sure to clean that excess flux off, it might cause problems later.
Question: why did you not buy the Boneyard Edition and save yourself the trouble?
The LDR is picking up room light. I move my desk lamp and I can hear the volume change.The LED could be bad or in backwards. You wouldn't be the first person to install an LED backwards. Hint: The LDR sees everything. If you want to test this with the board exposed, the room has to be very, very dark. A bad connection with the ATTACK or RELEASE pots would also prevent the LED from lighting.
Pretty sure that's correct, but I'm sure @Chuck D. Bones will confirm shortlyJust to double check - if im using the boneyard edition of the pcb, all mods are included in that, so its just a straight forward build as per the listed pcb components ?
Here's a silly question: are you testing this in total darkness? Any stray light will make the LDR resistance go down and the circuit will react by lowering the LED current.
Chuck D. Bones said:Changing R4 won't make the LED any brighter either, but you found that out already.
