DGWVI
- Build Rating
- 5.00 star(s)
Another analog multi Octaver thang, and this one definitely gives the Octarock a run for it's money.
The lower octaves are essentially an OC-2, but they actually have decent volume output, while the upper octave is fairly close, though not identical, to JC Maillet's Super Fullwave Octaver. The direct blend also offers up some decent transparent boost.
This thing's clean - excellent tracking in all pickup positions, and fairly minimal audio artifacts given it's circuit topology.
Having owned an original years ago, I don't remember it being quite this nifty, but I'm loving this one so far.
I'll have to do a shootout between this and the Octarock before I decide which will actually be staying on my board, but I'll be honest and say it's probably this one
This first demo is almost all bridge pickup
And this one focuses on the neck pickup
As you can hear, it definitely responds to the different positions in a pleasant way, and tracks well regardless
EDIT- I put it in this 1590BB because id already drilled it out for another project that turned out to be bunk, so figured I may as well use it. It could fit in a 125b with top jacks, and no issues as it's designed for a 1590B, but eff all that jazz
EDIT mkii - I forgot to mention dialing in the octave up. It is an extremely small window on the trimpot, and while tedious to find, it pops out like quite noticably
